BR Intercooler
Basic Sponsor
The BR intercooler looks nice and easy to install, does anybody has an idea how much does it cost?
http://951forums.com/forums/index.php?showtopic=370
1555.00 plus S&H to NZ. Thanks for posting this. I just got the email, and haven't had time. It flows 700CFM. Good to see NZ still pushing his engine.
It is NOT an easy install. You must cut the metal under stock IC between the rails. Then you have to fabricate some sort of setup to connect the frame rails. Unless you have a welded in cage that connects to the top of the strut towers, you must keep the front frame rails connected.
