Piggyback question
I almost have everything completely installed(Vitesse MAF, FPR, injectors, piggyback). It took a little longer than I had anticipated. I guess, because I got frustrated and quit on Saturday.
Ok, here's my question..... The instructions say to connect 2 wires to another wire TOWARD THE ENGINE. How far up the wire bundle do I need to look to find this wire?
Toward the Engine means towards the Engine side and not the computer side. So you have to connect 2 wires to one wire (if I remember right) and you have to cut that old wire. So, one that says Towards engine, connect right where you cut the old wire. The one labeled Towards computer or away from engine, is where you connect the other one. The OEM wire that was cut in half. Got it??
