Low HP - TO4E
I will try to post the dyno results at some time, but in the meantime I would appreciate some feedback, given the following data.
On a Dyno jet, my best numbers were 297 HP with a max torque of 300 at 18 PSI.
The set up includes a new TO4E (less than year and will need to verify the trim), Siemens 55 lb injectors, MAF, Guru chips, Lindsey dual port wastegate, MBC, 3 BAR FPR, Lindsey Blow off valve, 3 inch muffler, no cat. Vacuum per guage is about 18 after warm at idle.
Given the above and what I have read here, it would seem that these numbers should be higher. Therefore, my main concern is understanding whether there maybe some possible underlying mechanical issues that need to be addressed and the different possibilities. I plan on doing a compression test this week to start my diagnosis, but would certainly appreciate some pointers.
The car has just over 100K miles and to date I have not changed the head gasket,or had any work done in that area of the engine.
Biggles
Biggles
what are the turbo's specs? - hotside & coldside.
if u are still getting full boost at 3800-4Krpm then maybe an exhaust leak, intake leak, or wategate problem? Or the turbo could be too big i guess - how did it perform pre-turbo upgrade?
Formula One Spin Doctor
Hello ,
On a stock 944T , stock k26 , exhaust etc, with stand alone ecu we are seeing
260whp 300 ft/tq @ 1 bar boost. car was also high mileage deal , have more than 130,000 mls..
Originally Posted by A.Wayne
Hello ,
is it a 26/6 or 26/8?
Originally Posted by aeronautica86
what mods do you have to get 260rwhp out of the stock turbo at only 14.5psi?
what is running your MAF?
edit: your sig says apexi safcII
my setup was VERY similar and made the numbers in my sig. (before the to4e and had more topend power when I did install the t04e)
Originally Posted by R4][N_M4l{3R
Definetly makes a difference.
Originally Posted by RolexNJ
Actually a huge difference. I should know, I had the before and after. Now I'm blessed with custom Vitesse Racing MAF chips, wow! Once you have them, you'll never want another set other than his.
Better than LR and Auto?
Sorry for the OT, back to the program...
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Drive-by provocation guy
"And with his custom MAF chips, my A/F will always be dead on regardless of PSI levels."
I have never heard that before. Maybe I just missed it.
John, that is a MAJOR selling point !!!! Definately inlcude that in your marketing. No re tuning or tweaking needed.
ok, John, we gotta re visit trying to work on a chip for my maf/LR turbo and "off beat" injectors
ok, John, we gotta re visit trying to work on a chip for my maf/LR turbo and "off beat" injectors![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
