Koni vs. Leda coilovers
I will be ordering rear coil overs for my dedicated track car(deleting 30mm torsion bars). I am considering the 3012 Konis from Paragon and the double adjustable Ledas from Racers Edge. I have had great service from both of these companies in the past.
My car is running a coilover set up in front (600 lb. springs) and weighs 2380 lbs.
Does anyone have personal experience with either of these set ups? It has been suggested by one company that I run 700 lb rear springs and 600 lb springs by the other company.
Thank you for your input.
Kevin
Kevin
I'm running Ledas double adjustables. They've been
very reliable. You should strenghten the upper shock
mounts for safety precaution as you're going with
such heavy springs in the rear without torsion bars.
Thank you to those that have responded. Edge, I will be selling the torsion bars. 9fitty, are you running the 3012's? What rear spring rates are all of you running?
Kevin
Kevin
Kevin
Kevin
your looking at two very good companies. It comes down to which valving is better suited for you. Remember that if a Leda breaks or needs work, you'll be sending out to europe, waiting on parts, paying an arm and a leg. Koni has parts on the shelf with stores usually local (to me at least) ready to fully rebuild for cheap and even free. (if the warranty applies for the 3012 series, which I would go with over the Ledas)
Anywho, thats mainly opinion. I'm a Koni guy. (no experience with leda)
Eyal
Eyal
Edge,
Yes, you can buy them. Obviously, I need some time to remove them. This will depend on which company I go with. There is a five week diference in delivery time. Make me a reasonable offer, and they are yours when I remove them.
Kevin
Kevin
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Eyal
Eyal
Koni makes good stuff - the main difference is that the Ledas are custom built to your spring rate.
Either way you will be happy!
Chirs White
PS - I am a Leda dealer so I may be just a tad biased...
From a relatively unbiased point of view, Eyal's post is complete BS.
Sent my Ledas to Karl for rebuilding under warranty. Karl had them back in 2 days, and also upgraded the rear mounts to spherical bearings. Service and support are excellent for the Ledas, and service is located in the USA!
-Jon
-Jon
