Busted turbo.
If it's not one thing its another, first it was my arms and now the turbine.
The turbo is the one from the Lindsey 363 rwph package. I hear that it's actually a To4e or something like that. Correct? Do you guys think a rebuild is possible?
Is it oil I see around the hose? Looks pretty much to me. Maybee a crank case breather is next in the upgrade list?
(maybee you should check your leakdown numbers if theres way to much oil there)
And whats up with the hose, at the bottom left corner?? Is the hose damaged? A part of the hose gone?
