Tial Install Need Help Quick
You should order the the Lindsey black **** boost controller and their guage panel. Tell him to machine the panel for the black **** and for 1 52mm guage. Put the guage on the left and the **** on the right.
Legend Killer
Legend Killer
Does anyone have a good clear picture of the Tial installed? Woudl the install be any different on an 86? When I searched this site I have found conflicting pics of the tial install so it has become very confusing.
Legend Killer
cool thanks......so the exhaust goes into the side of the tial and then out the bottom. Confusing. How does the vale open then? When I looked at the tial it seemed the spring would pop up toward the top but does it actually pop down toward the dump tube?
Legend Killer
Originally Posted by Andial951
Sir....I have done as you have said sir....Lindsey black **** and gauge panel on its way sir. Sir....any suggestions for good boost gauge sir?
What kind of chips are you running?
Basic Sponsor
Special Tool Sir, mr cantinflas te anda buscando. Sir
You described it backward. The exhaust gases go into the bottom of the TiAL (valve opens inward) and dumps out the side.
Legend Killer
Andial - yes look at the picture - the exhaust goes in the side via the crossover.
I really like the Defi guages because of the broad range -25 to 35 psi.
If you want something cheaper that matches the stock VDO guages, get the VDO cockpit - 25 to 25 psi - and it really matches well.
Dismissed.
Dismissed.
No disrespect. It's just the way everyone's describing it. "exhaust" could be conceived from either end the way I read it. The exhaust gasses exiting the engine from the manifold enters the wastegate through the Bottom. It exits out the side to the actual exhaust pipes out the back of the car.
Just to be sure it's clear. But the picture does truly show it.
The Stock one seems to do just the opposite.
