Smoke and oily spark plug on 4
Hi,
I have a small problem with my car, firstly it smokes at idle and on the over-run, this has gradually been getting worse. plugs 1,2 and 3 are fine, 4 is black and oily. Am i correct in thinking this could be valve stemm seal. I havent been able to do a compression check yet.
Also in looking for the above i took all the intake pipes off. There is very little oil in them, i looked in both ends of the coldside of the turbo, and bone dry no oil.
However when you the shaft there is a small amount of movement, both in and out, and left to right. if that makes sense. But it is at most 0.5 of a millimetre, sorry i dont know inches very well but a covertion calculator said it was 0.00164 of an inch. Its very small you can feel it, and just about see it.
Is this too much play or not ? I have always done stuff with cars, but this is my first turbo car, so I'm not really familiar with what good or bad turbos feel/look like.
Any help would be great
Update to above
I have taken the intake off. when i looked down into the intake at the valves, 4 happened to be closed. But there was qhite a bit of water, but kind of greasy, like it was water vapor from the engine. So it would appear that some of the smoke is water vapor, but why so much?
