Dyno results and questions
Originally Posted by streckfu's951
Was that a 6 or 8? and at what psi? I was comparing the high TQ to an average HP. His boost bleed-off is typical of a stock WG so with 292TQ, I would expect him to be pushing about 250HP.
This is just speculation though without having the AFR and boost mapped as well.
It's is supposed to be the stock k26/6. I was peaking at 14/15 PSI on the dyno, but normally hit 17 on the street.The wastegate is also stock....I've been planning on replacing it, but might go with vitesse stage 3 and a full 3 inch exhaust at the same time.
Thanks,
Jeff
Originally Posted by cotton
I wonder if the boost would have held maybe I would have had better HP numbers? When does a 951 usually hit peak HP?
Thanks,
Jeff
Thanks,
Jeff
