FS: top of the line greddy boost controller
asking $200 this is a damn good deal!
the unit is used.
but works just fine.
I NEVER removed the clear plastic that covers the screen, so it has zero scratches.
only the controller shows minimal wear but that's it
it includes the screen, controller, pressure sensor, center unit, valve unit, data card, instructions manual and all the other wiring and bracket goodies
I don't have a turbo anymore so I don't need it!
I thought this controller was causing issues with my car but it turned out to be a backwards wastegate and a bad afpr
I had it hooked up to display boost and my rpm
I had the unit set at 15 psi but I could hit a button and for a predetermined set of time (I set mine at 10 seconds) it would run 20 psi (also adjustable)
for when I was really in a hurry!
it has a low and high boost settings too
I kept it in graph mode which allows you to see in real time and the last 10 seconds (my graphs were never as bad as the one in the pic though), but it can display everything in 4 different modes
it can datalog for 3 hours
can show a/f, egt, etc,
this thing has so many options it's crazy,
gain lets you adjust how rapid the boost comes in (for sorry saps like me who didn't have lsd!) - it can make a huge difference
hooks up to emanage
peak values
warning indicators that you set
the unit can learn your cars boost habits
duty cycles, ignition maps airflow maps, injector and sub injector maps
I'm pretty sure this unit can blend you a smoothie too.
heres a breif description that doesn't even state half the stuff this unit can do:
"GReddy's new super multi-tasker is the PRofec e-01 designed as a combination boost-controller, data display / logger and e-manage programmer. The e-01 can provide superior boost response, increased boost, warning meter functions, 3 channel data-logging and access to all the programming features provided with the latest e-manage support tool. Even when used as a boost controller only, the e-01 has features to smooth out the boost curve. With both an auto and manual setting for both external and actuator style wastegates, the new PRofec can alter its new compact, high capacity solenoid valve via various RPM ranges. The large LCD screen with green electro-luminescent backlighting is easy to see. Other standard features include two preset boost levels, a timed over-take boost and compatibility with our Remote Switching System. The data display can view 3 different data channels simultaneously such as boost, RPM or any other channel inputted by the e-manage. The data can be logged up for 3 hours on an SD card while also giving warning set points and peak and hold values. There is also a non-PRofec e-01 version that is only used for e-manage programming and data logging. (Some features require optional harness to be accessed.) "
the unit can be set to PSI, (HG, KPH, kg cm2 not that I know what the hell these things mean!)
here's a pdf of the manual which shows everything it's capable of:
http://www.importscene.com.au/files/profec_e01.pdf
the unit is used.
hooks up to emanage
peak values
Eric, I'll take it. Email me directly with the details on how to proceed.
