Fluttering Sound on Boost.
Rocket Scientist
Just like the title says there is a fluttering sound on boost. It seems that the car hesitates a little during this flutter. Sometimes its there, sometimes it isn't. It's at both part throttle and WOT. I thought it could have been a torn divertor valve and I replaced that. Didn't change a thing. Please don't tell me turbo...
Rocket Scientist
Will do, thanks Tom.
When it is the acutual turbo having problems, they are silent correct? Even when a turbo is on the verge of throwing itself apart it doesn't make a sound. Is this correct?
You can have surge under boost....if it's a badly matched or dying one. Then it runs smoothly at first when you floor it and the boost builds,then hesitates/stutters as the rpm rises ,and then back to smooth again at high rpm... Most turbo's I've heard on the brink of imminent brutal death gives off a high-pitched whine,much louder/higher pitch than the normal whistle most turbos give off...
Originally Posted by Tom M'Guinn
Check your I/C pipe connections -- when they get loose, they can let boost out, causing funny noises and an overly-rich hesitation.
Rocket Scientist
Well it is not the divertor valve as I have replaced that. It is also not an intake leak. I think it may be running lean. I set the boost on the car when it had exhaust leaks and now I have fixed those leaks so its gotta be running lean. I'll slap a boost gauge in there and see whats its running. Thanks.
