Best Clutch?
Ok, the 930 disc is on the left, the "Cup" disc on the right. The band of friction material on the 930 disc is about 1/4" wider than the cup disc.
Your Porsche Parts Superstore
![](http://www.paragon-products.com/v/vspfiles/assets/images/pagidrs2.jpg)
![](http://www.paragon-products.com/v/vspfiles/assets/images/Paragon web logo.gif)
![](http://www.paragon-products.com/v/vspfiles/assets/images/konilogobkbgsm.jpg)
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
will a high pressure KEP pressure plate accelerate the wear on the crankshaft thrust bearing? and if so how many street mile could one reasonably expect from the thrust bearing?
Originally Posted by David Floyd
KEP stage 2 pressure plate
"EZ Lock Pro" 6 puck copper/ceramic spring center from www.clutchnet.com
Will save a few pounds also
My vote goes to KEP Stage 2. Even when spongy from being half bled or a dead cylinder its as stiff as stock!
Regarding 6 spring vs. 4 spring clutch plates: It has been said that with 6 springs, there is greater likelihood that a spring will dislodge and jam the works, with expensive consequences.
Can anybody with empirical evidence confirm or deny this?
