Wolf 3D EMS
#61
the wolf3d has datalogging. i'll post up some pics later.
tuning can be done rpm vs. boost, by using different boost levels. i'm actually tuning from 12psi up to 21psi and i'm currently at 14psi working my way up.
#62
datalogging. the left and right values for each of the four graphs are user-defined/selectable;
the ignition map. notice that you can move/rotate the graph to be able to see it from any angle;
bigger pictures here;
http://gallery.silentmedia.com/v/alb...bum124/wolf3d/
#65
it's because the samples are at 1/100th of a second. the analog vdo gauge shows steady boost at 13psi. i can slow the sample rate on the wolf3d down and it will show a smoother graph. i'll play with it more later tonight.
