anybody raise their compression ratio?
When those of you who have went 2.8 or 3 liter raise your compression ratio any? Also has anyone ever heard of using NA pistons to do this on a stock bore motor? Just throwing some ideas around Thanks
Same here. Mill the head .050 for a new CR of 8.5:1. I would really wanted to go to a 9.5 to 9.8 CR, but I can't find anyone that can make the right pistons for ths application. The mayor problem, it seems is the piston special coating for it to work on the block. The only company that says that they can make it is Cosworth Ltd., But they can only produce 20 or more.
Regards,
AL
Regards,
AL
Regards,
AL
Regards,
AL
Yep, I'm building a motor for my 951 using N/A pistons. 100.5mm N/A pistons, 9.6:1 CR. I plan to run ~15psi of boost, and it should have an awesome torque curve, be quick to spool, and go like hell.
You could use the 10.something:1 pistons from a late N/A if you were really determined though
I always thought that a lower compression would allow more aggressive (higher) boost, and thus more power. Wouldn't raising compression a sizeable amount reduce power potential? Wouldn't more low rpm torgue be better accomplished by avoiding a large tiurbo, opting for a smaller turbo that hits harder at a lower rpm? Hey what do I know.
EdC, if you want to run 20-30 PSI, don't raise compression. The gains you see from being able ro trun 25PSI are far greater then 10:1 CR and 15 psi. But if your going to run 15 psi either way, and no more, then 10:1 on 15 PSI will yeild gains. I'm running 18 PSI on 8.5:1 with out any real problems.
~Eyal
~Eyal
Higher CR gives more off boost power, but a lower threshold for boost before running into knock/etc. But, higher CR is another way of getting more power out of any engine. Porsches new engines run 11:1 or more of CR.
Its really a matter of what you want from the car...
Not necessary Edc, you could make lots of power with a high CR(9.0-10). The reason that they us a low compression pistons on older engines was because ignition timimg was still perty primitive and pre-ignition was a big problem. To control this they use this type of pistons.
Regards,
AL
Regards,
AL
I'm running new Mahle 968T 8.0:1 CR pistons. I wanted this low of compression because I didn't want to ever be limited on higher boost levels to due a higher CR.
EdC: You are right about your comment too. A higher CR would impede you from running higher boost levels "safely". Some of the people I know of wanted higher CRs because they wanted a more responsive low end - N/A type. Not me, I want boost baby!
That is true Rolex, I want to do this because I want more power off boost.
Just think about this. Indy cars,(CART not IRL) run a CR of over 12:1 With a single turbo with methanol as fuel and no intercooler, and can produce 850 BHP from 2.65 L. All of this at a phenomenal 7 psi.
Regards,
AL
Regards,
AL
You might send your questions about having pistons made to technical@klaindustries.net Tom has had some made with very good luck and we can get the proper coating put on the skirt.
Ken
Ken
