Oil leaks near oil filter
I have an oil leak near my oil filter. Before I changed my oil today I tried to tighten the oil filter by hand and it wouldn't budge. I tried my oil filter wrench (not too much torque -- fear of strippage) and it didn't budge either. My oil filter is on tightly, so I doubt its leaking from there. What else is in that area that could leak oil? I saw the Oil pressure sender, but I believe that's been replaced 4 years ago at 56,000 miles by the previous owner. The car now has 91,000 miles, is it possible the sender needs to be replaced again? Is this a typical problem area with 951s? This morning as I started the 951 up the low oil light came on for a second and the gauge took a second to go up (maybe normal, I'm just getting paranoid lately due to odd smell coming from engine bay, most likely a little oil burning), possibility its the oil sender? What else should I check? Is the oil pump in this area and what are signs thats going? I would like to visit my friend today about 30 miles away. Should I cancel the trip or this isn't something urgent?
check the oil pressure releif valve. Its that big 24mm bolt next to the sender. Maybe its loose? Otherwise, the cam tower gasket could very well be leaking.
~Eyal
~Eyal
I recently replaced the oil cooler housing gasket and orings because of an oil leak. First time I ever saw an external leak on 944 t. You might want to look at that as well.
I believe I have a leak at my oil pressure sender, but I haven't fixed it yet, so I'm not completely sure. I'm going to try a new crush washer and teflon tape on that first. If that doesn't fix the leak, I'll have to look around at more things in the area.
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
spray the area with a degreaser when the engine is cold, rinse off with a hose and you'll probably find the leak the next time you drive it.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
87951
Originally Posted by bearone
when you changed the oil did you change the filter or just try to tighten the old one to stop the leak?
87951
87951
What kind of degreaser do you recommend? I use Simple Green without diluting it so its most powerful. Anything out there thats better/easier? I was out of simple green so I didnt get to clean it today.
EDIT: It is dry around the oil cooler.
It is also dry above my oil filter and around the top of the engine that says "PORSCHE" so my cam tower gasket should be fine right? Cam tower gasket and valve cover gasket are the same thing?
use the degreaser all around where you see oil has accumulated.
be careful with the hose when you rinse it off. water and electrics don't play well together.
i use stuff from costco. it has a citrus smell, is environmentally friendly and does a decent job on the lite stuff.
87951
87951
you do realise that removing the oil filter will spill oil in that area, looking like a leak if you didnt realize that it spilled... Just needa get that out of the way.
~Eyal
~Eyal
Clean it up as with degreaser -- getting rid of all oil and grudge in the area. Then take it for a spin and check to see where the oil is coming from. Possibilities in the area include the oil sender, the oil cooler lines that connect to the housing, lower balance shaft cover, the housing to block seal, not to mention long-distance leaks and power steering leaks...
See pictures of leak possibilities here: http://members.rennlist.com/tom86951..._seal_repl.htm
~Eyal
~Eyal
![](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/83001-oil-leaks-near-oil-filter-oilgarage.jpg)
Here is something interesting I just noticed. I took a picture of the passenger's side wheel well, there is oil in there.
![](https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/83002-oil-leaks-near-oil-filter-pdr_0056.jpg)
I change my oil every 2000 miles (2500 miles at most) and I never need to add oil during that time. However, I've never seen oil on my spashguard before.
external oil cooler lines that attach the the block mounted cooler can leak. They have pressed on fittings that get old and brittle. When you run the car at speed the wind blows oil everywhere making it difficult to pinpoint the source. Clean the motor up and jack up the front and let it idle for a while and check to see for leaks when the car is at rest, otherwise it can be extremely hard to find the source. Make sure it gets hot, there is an oil themostat for the external cooler that will cut flow until hot.
good luck
good luck
good luck
good luck
I have a trace of water on my oil filer cap so I'm going to reseal my oil filter housing. If you guys had to do this job again, what would you do differently?
I've read this website a couple of times:http://members.rennlist.com/tom86951..._seal_repl.htm
At the bottom is says to buy (2) 123-011 I have these (22 x 27mm)washer/seals but where do they go the article doesnt mention them?(#9 on parts list) Is this only when replacing the oil lines and do they go on the oil cooler radiator or on the oil filter housing end of the oil lines? If I dont replace the oil lines, and they attach to the oil line & oil cooler radiator end of the oil lines then I dont need them because I don't touch the oil line connection at the external oil radiator, I only disconnect the oil lines at the oil filter housing? These are questions for the Turbo owners because I understand this is how the n/a and turbo are different. i dont think the n/a's have an external oil radiator
If this does not stop my oil leak and I need new oil hoses, that should be a simple job right? I dont need to remove the oil filter housing again to just replace the oil lines?
I think it might be where the oil lines are connecting to the oil filter housing where my oil leak is. If I don't leak oil when the engine is running cold, and only leak when the engine is hot that means the oil lines are leaking? Do I need to replace the lines or just the washer? They are a little over $100 each oil line at pelican, is there a cheaper solution?
A little trace of water on the cap doesn't necessarily mean anything. Condensation often collects and shows up on the cap. You need to remove the housing to replace the oil seals, but you "should" be able to get the hoses off without removing the housing.
