Greddy Profec-b or Profec-S?
Old 10-09-2005 | 03:44 PM
docwyte's Avatar
docwyte
Default Greddy Profec-b or Profec-S?
What's the difference between these two? Are they basically the same, with the S being a newer iteration without manual *****? Which should I get?
I'm kinda attracted by the simplicity of the profec-b...
Old 10-09-2005 | 08:31 PM
hally's Avatar
hally
The type s sounds simplified, next generation and claims a bigger solonoid.
http://www.suprastore.com/greddyprofecb.html
Old 10-11-2005 | 01:47 AM
95ONE's Avatar
95ONE
New here, but not to these Boost controllers. let me tell you how Crappy the Profec B is with the small solenoid. Stinks! Rarely keeps boost constant. Works fine for a little while then starts messing up. A little bit of heat will screw up the setting . (Solenoid or wiring) They went back to the larger solenoid for a reason. Go with the newer one.
(I work at a performance shop in Houston by the way.)
Old 10-11-2005 | 10:12 AM
Dr. Dynamics's Avatar
Dr. Dynamics
If Greddy is your desicion, go with the spec II. Additional things it has is solenoid sensitivity, alarms, safety boost setting, plus a cleaner look.
Old 10-11-2005 | 10:51 AM
sweanders's Avatar
sweanders
I installed the Type S on a customer car and it worked very well. I like that it is so simple and straight forward to set.
Old 10-11-2005 | 03:43 PM
dme's Avatar
dme
never had a problem with my profec B. Came with the car and works flawlessly. Never have to think about it. Set and forget.
Old 10-11-2005 | 05:45 PM
ewainwright's Avatar
ewainwright
I also have the Type S and I am very pleased with the unit. Very simple to use and you can purchase it much cheaper on ebay brand new.
Edit: Last year it cost 250. This year the best price is 270. Good Luck
Old 10-11-2005 | 05:47 PM
streckfu's's Avatar
streckfu's
How available is the profeb b II? Has the price come down a bit?
Quick Reply: Greddy Profec-b or Profec-S?
