brakes and clutch feel different
After doing the venturi delete and all new vac lines, effectivley eliminating around 10 leaks...but now my brakes and clutch feel stiffer. is that normal?
The brakes MAY feel different, but the clutch should not. If the clutch is too stiff, you can set the peddle force lower by adjusting the spring tension.
The adjustment is up under the dash board. It can be a pain to get to but its not impossible.
