so im at the gateway.I.R (dragstrip) run a 13.6@105mph
Originally Posted by tonyzp007
i don't realy know ,i just know under peak acceleration the cars boost needle is exactly at the 2 mark ,i dont have a psi boost guage yet nor a boost controller . after i change the head gasket i will install a boost controller and guage
It would be much easier to install the boost controller while everything is apart for the head gasket. You should also look into removing the venturi crap and upgrade your WG to complement the boost gauge and controller.
You, know. While you're in there and all.
once i get it all apart i will probably be on here every day because i know i will probably need some help figuring out where this venturi is and where it goes also where to hook up boost controller and gauge ,and what kind of bov to use,thanks--- tony
