APEXI SUPER AFC SAFC2 SAFC 2 II AIR FUEL CONTROLLER
I found one of these APEXI fuel controllers on ebay for a really good price...Would they work with my Authority MAF kit??
i know when i had my huntley racing maf the safcII worked very well. i believe it will work with ur authority maf kit if i remember right because it uses 0-5volts
the safcII was very easy to use to tune with and had a bunch of features for the price.
Mexican Ambassador
not to hijack the thread, but how does the SAFC-II work on the stock AFM? i was considering using it, but the guy at the local speed shop advised against it, since it goes off the TPS, and doesnt account for boost? or am i getting this *** backwards?
the install was very easy when you have a maf. Gururacing helped me install it and came up with a sheet with all the instructions needed. I am not sure if i still have the pdf file of how to instructions so you might want to contact danno. ON the part with if it will work with the stock afm i am not sure but i don't think the sensor will work maybe you will have to ask someone that might know more about that.
