MAF after BOV
MAF after BOV
Has anyone located the MAF after the BOV allowing it to vent to the atmosphere? I have done it on a DSM. It adds a little bling and eliminates some hoses under the hood. I'm getting ready to put a MAF on my 951 and am looking for suggestions.
It can be done. It requires a special type of MAF.. The software (chip) will have to change as well.
i've often wondered this myself, wouldnt this allow for one of those forge rally-type bov's? john, what kind of mods would have to be made to a vitesse chip to do this? i've always wanted that "PSSSHWEE"
I don't know about Porsche, it could be done on a DSM before or after the bov without modification to the programming.
Yes Obsession, if it were able to be done you could use your factory bov and just take off the return hose.
I have an MAF coming. Do they look capable of holding 20 lbs of boost without cracking?
On the Lindsey site they say that the pro-m can run nearly any MAF. If that is the case it could probably use a GM MAF from a Corvette, MonteCarlo and a few others. They can be bought at a junk yard for 50.00. They work very well under boost conditions from my experience, made from cast aluminum and if I remember have a 2 1/2 to 3" inside diameter.
We already have the software & MAF to do this.. It requires a different IC pipe, which is why we do not offer it as a product.. I doubt we will make available on a per order basis..
I couldn't find any pictures of I/C pipes on the Vitesse site. The Lindsey site has a pic on thier homepage. There looks to be a good location on the upper intercoller pipe for the MAF. All you need is a straight piece for about 6-8". Also if your system uses intake air temp that would be a good location after the intercooler.
I would go and look at my car but it has been at the tint shop for 5 days. Evidently the rear window is a pain to tint nicely.
Of course you did not see any info on this particular part, as I said we have no ontention on selling it. Also before you go spending $ on a GM MAF, best to make sure it can work on the 951.
I have my BOV vented to the ATM. No problems at all except it almost stalls if I tap the gas and let off quickly while sitting in neutral. A few companies make BOVs with an antistall option to prevent the BOV from sucking air back in. I will try one of those eventually but for now it's fine.
Fast951,
"It requires a different IC pipe, which is why we do not offer it as a product"'
"Of course you did not see any info on this particular part, as I said we have no ontention on selling it."
From your first post I gathered you sold the "not different" I/C pipe and it was not listed on the site.
I already have a MAF currently marketed for Porshe coming. I'm just putting out possible options for new or current technology.
Eniac, If your bov is vented to atmosphere but is after the maf(as the air flows) you will have a rich condition every time the bov releases air. The air is metered and fuel will be added for it. When it is released the computer can't know to reduce injector pulse.
If your bov is before the maf someone smarter than me might be able to help.
Originally Posted by Glider
Fast951,
