For the disbelievers. . . .
#31
Originally Posted by Tom M'Guinn
I am going to visit Scott Gomes tomorrow, schedule permitting, so I can get my 3 liter project together once and for all.... then maybe we'll get to see what STAGE 5 can do.....
He knows his stuff. . .
#33
Originally Posted by tedwright
I want to order his BS delete kit, but I am kind of tapped out here for a bit!
Downloading videos now...
#34
Originally Posted by sh944
Still sleeping on the couch? lol (The hard pipes should be showing up shortly).
Regards,
Regards,
I wouldn't even been able to get the hard pipes from you if we didn't work out the trade!! I am looking forward to getting them as my stock pipe keeps blowing off at anything over 20 psi. . .
#37
Originally Posted by NZ951
I would like to order a BS delete kit for someone I know
. . .from 1600 rpms in 3rd? Um no, it is not quite like that. In 4th gear, starting at 2k rpms and flooring it, I will get 17psi at just under 3k rpms.
#40
Well, I went through each frame and it held 10.5psi for 3 frames.
I had someone PM me and ask why when I go to the tach shot the factory boost gauge only shows 3-4 PSI. I would imagine that is because of how slow the factory gauge is to react. If (at least on my car) you watch your aftermarket gauge and your factory gauge, there is like a 1-2 second delay in the factory gauge compared to the aftermarket one. Just some food for thought. . .
#42
Originally Posted by special tool
You guys wouldn't believe how high your tachs read, either.
#43
Skunk, I can tell you exactly what mine was out. I took it out and ave it to a local shop and we tested it. Up to 4,000 rpm it was very accurate, above that it started to waver, at 6500 is was overestimating by 400rpm.
#44
Nz - no kidding!!!!! That is exactly the difference between my zeitroinix (and every dyno) and my tach at 6500.
That's the reason I lifted so early on my last dyno run, looking at that piece of **** instead of my laptop.
