2 questions...one is an idle issue...
This is on an '86 951, the idle is at 800 cold and at 1200 warm which it sometimes spikes up to 2000. I have already checked the TPS, rebuilt the TB, checked and repaired all vacuum leaks, remove venturi, etc.
Before I go and order a new ICV I am wondering what else could cause this idle problem. Ideas??
Second question. This car has Autothority chips, will these chips work with a 3 bar FPR or do I need new ones that are designed for a 3 bar FPR, or doesn't it matter?
Anyone know about using a 3 bar FPR with Autohority chips? Any problems?
I did a search regarding idle problems which pretty much comes up as a vacuum leak being the usual cause. I have already fixed all the vacuum leaks.
I'd clean the ICV and see if that works. In my experience with all cars they tend to stick after a while because of varnish build up. Carb cleaner sorts them out.
With the chips if they are designed for 2.5bar and you put a 3bar FPR on you will be rich unless they have a jumper setting or something you can change to tell them the pressure is higher.
