I finally finished my turbo swap!....but now after over heating she wont start!
Old 09-12-2005, 04:01 PM
Eyal 951
Eyal 951's Avatar
you ARE mixing with water too right?
~Eyal
Old 09-12-2005, 04:19 PM
Nine_five_one
Nine_five_one's Avatar
^yeah
Old 09-12-2005, 04:22 PM
Nine_five_one
here are the RESULTS...
She still over heats, does not blow hot air, Water in expansion tank stays cold and coolant and air spurs out of the bleed screw.
what am I doing wrong? I did change teh thermostat is there a chance I screwed that up?
Old 09-12-2005, 04:49 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
Looks like something is up with the thermostat.
Old 09-12-2005, 05:12 PM
Ski
Ski's Avatar
Which end did you put to the INSIDE of the water pump?
Old 09-12-2005, 05:18 PM
Jaak Lepson
Rest In Peace Jaak
Cable Guy
Jaak Lepson's Avatar
Some folks who rebuild engines drill a 1/4" hole in the thermostat. If you are blowing air as well as coolant ... still need to bleed the air out.
You also have a problem with your cooling fans. Is the temp sensor pluged in at the rad, is the fan relay in the fusebox plugged in? If the fans don't turn ... trace out the problem.
Try pouring some coolant through the bleed hole with a funnel.
Old 09-12-2005, 05:36 PM
AlexE
AlexE's Avatar
You definitely have air in that system..........
The fans won't kick in if he has air pockets and the sensor is not in contact with coolant.
As has been suggested while you have the bleed screw open
- rev it up......
- Squeeze the hoses
- turn the heat full hot
Just dont overheat her for too long.......
Old 09-12-2005, 05:41 PM
Nine_five_one
The end the end that is closest to teh sticker.
Old 09-12-2005, 05:46 PM
Nine_five_one
- rev it up......
- Squeeze the hoses
Ok I open the bleed screw and a bunch of air with coolant keeps coming out, I squeeze the bottom radiator hose and I also put the heat to full hot...results..
1.she over heats
2.Coolant in expansion tank stays cool
3. No hot air blows
wf!! Maybe i aint bledding it right?
Old 09-12-2005, 05:49 PM
Ski
Ski's Avatar
You need to flip it if I read your statement correctly. The end with the spring and plate need to go into the water pump - the plate at the end seals against a seal in the water pump after it opens to force water into the engine and on its way.
sorry for the big picture
Old 09-12-2005, 05:59 PM
Techno Duck
Techno Duck's Avatar
If you mean you had the portion with the spring facing out of the waterpump, i am pretty sure you put the thermostat in backwards.
Old 09-12-2005, 06:00 PM
Campeck
Campeck Rulez
Campeck's Avatar
yeah man. flip that thing around!
Old 09-12-2005, 06:04 PM
Nine_five_one
HOLY @43%#@%@#$!$@#%$!@#%$312%$#!@^%#%^!@#%$#!@53465!@#%!@$#$@354#%$123%$#%$# !%^$#%^ WTF!!!!!!!
When i went to replace the thermostat it was with the spring facing out, so I installed it that way!
Before that car would always heat up to the tip of the red zone on idle and my fans would always turn on after I drove her... I guess I know now why!
OMG!!!! I will flush and replace ASAP!!!
THNX for the pic and info guys....i am a much wiser rookie now.
Old 09-12-2005, 06:30 PM
Nine_five_one
Double checking this side goes in first ...right?
Old 09-12-2005, 06:34 PM
95Juan
Mexican Ambassador
95Juan's Avatar
seems like the pointy end goes in first, as how the water will move the spring/hat mechanism that way......i could be wrong.....havent done a thermostat in a while.
Quick Reply: I finally finished my turbo swap!....but now after over heating she wont start!
