Tuning question
Old 09-10-2005, 07:52 PM
schnellfahrer
schnellfahrer's Avatar
Default Tuning question
My Vitesse stage 2 kit makes nice power at 15psi and ~12:1 a/f ratio. As long as I keep the a/f ratios around this level under boost, I'm pretty safe. Now what if I want to run more boost? I know; "add race fuel". But is there anyway to monitor if I'm making more power safely? (Like I would with checking a/f ratios).
Do I monotor knock? EGT? What am I looking for?
Old 09-10-2005, 07:57 PM
RKD in OKC
RKD in OKC's Avatar
A/F is a good thing to use as a guide.
Old 09-10-2005, 08:00 PM
NZ951
NZ951's Avatar
Do a quick search for Link Knock Block. I did a wee write up on it with some pics. Also, on pump gas I can run 20psi with around 19 degrees of advance and 11:8-12.0:1 AF and zero det. EGT is another good check, I am putting 4 in when I get my new headers (a couple of months away). Its a bit more expensive to measure EGT though...
Old 09-10-2005, 08:02 PM
TRWright
TRWright's Avatar
If you put in race fuel and crank up the boost, your AF is going to stay dead on the money (exactly what it is at 15psi) thanks to your Vitesse software/MAF. The thing you need to be on the lookout for is EGT.
Call zeitronix and order the EGT probe for your zt2. It will come with a bung that you need to have welded in the 4th exhaust runner.
Old 09-10-2005, 08:04 PM
NZ951
NZ951's Avatar
Great call Teddy, I didnt see the ZT2 in the sig...
Old 09-10-2005, 08:09 PM
schnellfahrer
Thanks guys. So what EGTs are safe?
Old 09-10-2005, 08:11 PM
NZ951
NZ951's Avatar
Eivind, its a bit like which AFR is safe... some comment that 1500-1600 is about the max you want to go.
Old 09-10-2005, 08:34 PM
fast951
fast951's Avatar
Eivind, Before turning up the boost, set the FQS to position 4-7 to pull some timing out. EGTs and AFR are good indicators, however knock is the thing to look for... Thomas is getting great EGTs, I expect the same from your setup...
The software you have on the chip uses a fairly aggressive timing. The new software that we now deliver on a board provides 2 maps (pump gas timing and aggressive timing). So make sure, when people advise you, to know which software they are using...
Again.. here I go again: I only recommend 15psi MAX on pump gas.. (But nobody listens ).
John
Email
www.vitesseracing.com
Old 09-10-2005, 08:51 PM
NZ951
NZ951's Avatar
Hang on John, are you sure you dont recommend and quote your kits 24psi and race gas?
Old 09-10-2005, 09:20 PM
fast951
fast951's Avatar
Yes!!! Some people think I only quote hi-boost non pump gas numbers. What they fail to remember, that Vitesse kits perform on pump and race gas.... and they kick *** in the process..
Old 09-11-2005, 12:31 AM
ehall
ehall's Avatar
Well sure John, but does it come with one of these for Andrew?
Old 09-11-2005, 12:51 AM
NZ951
NZ951's Avatar
Elliott you bitch, I told you the photo's of my night outs were not for public viewing, thats the last time I send you them, so dont ask again.
Old 09-11-2005, 12:52 AM
ehall
ehall's Avatar
Atleast i posted the pics from the "attractive one". Cry baby!
Old 09-11-2005, 12:56 AM
NZ951
NZ951's Avatar
Yeah your momma is wicked hot, she loves the harness
Old 09-11-2005, 01:00 AM
ehall
ehall's Avatar
lol
Quick Reply: Tuning question
