How do I do a compression check???
Done With Sidepatch
Nope...it's all the same procedure. It's usually best to do it on a warm engine. Here is a link (ignore the talon reference) with straight forward instructions.
http://www.dsmgrrrl.com/FAQs/compression.htm
UAE Rennlist Ambassador
Originally Posted by Alpine951
Is 2 hours after shut down too long to wait to do the test?
Campeck Rulez
i got 220 on the NA. woot for high compression....sorta. ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
something weird happened during my test. the #2 cylinder would over pressurize the seal on the comp tester. and start blasting air at over 220psi out of the sparkplug hole....freaky.
Don't want to steal the thread ... but along these lines, how does one do a leakdown test? Do you need special equipment to do this, or just a compression gauge?
mntnman82,
you asked my next question so don't feel like you stole the thread. I did the test again this morning after taking it out for a drive. I am losing a good amount of oil which is why i did the test.
#1 130, #2 116, #3 133, #4 135. That #2 worries me.
I put some oil in each cylinder after these readings and all pressures went up to either 155 or 157. The number 2 spark plug was all black. It had some slight oil on it but the tip, electrode and insulator had hard black carbon all over it. I was hoping it was a valve issue instead of rings but after the pressure in #2 went up after adding the oil now I don't feel so good. Any one have any advice? I guess I need a leak down test.
I put in a used k27/6 earlier this year that there was not any info as to how many miles were on it. The play seem OK and it spun easily. I am going to try and pull the ic pipes off to see how much oil is there.
Campeck Rulez
ok. do you have an air compressor at your house? capable of 100psi?
leakdown testers i think you can rent or buy and they arent to expensive. and will cut the troubleshooting time down to nothing...cause you will know whats wrong.
plug it in. turn the **** and put it at 100 psi. open the throttle..listen to the intake. no noise, then your intake valves are fine. listen tot he exhaust, no noise, exhaust valves are fine. take the oil cap off, you should hear a *slight wooshing, but if its anymore than that then it could be your rings.
