Advice on Pricing
Advice on Pricing
Well my car is now running great. I would like to get an idea of what something like this is worth:
1986 944 Turbo
128,000 Miles (engine rebuilt at 122,500 miles)
Engine:
2.5L (1987 Engine with automatic tensioner)
Ported & Polished Head
Wide Fire Ring Head Gasket
Modified Oil Baffle Pan
T04E Garrett with V Trim
Adjustable Fuel Pressure Regulator
Wolf3D Engine Stand Alone System with J&S Safeguard
SFR Hard Pipes
Godzilla Blow Off Valve
Fuel Rail Gauge
LR 3” exhausts
Siemens 72 lb/hr injectors
944 Turbo Cup Clutch w/Racing Pressure Plate
LR Dual Port Wastegate
Suspension:
Slotted Front Rotors
Pagid Orange Pads on the Front
ATE Super Blue Brake Fluid
Steel Lug Nuts
Paragon Products Camber Plates
17x9 and 17x10 CCW Wheels w/Gunmetal Colored Centers (255/40 and 275/35 Kumho Victoracers)
17x7.5 and 17x9 993 Cup Replicas (225/45 and 255/40 tires that are mixed and matched)
Bilstein Coilovers (front 600/180 and rears 565/218) w/H&R Springs (500lb front and 550lb rear)
MO30 Sway Bars
Racers Edge Inner and Outer Spring plate Bushings
Corner Balanced and Aligned on 8/10/2004
Interior:
Gauge Panel Under Stereo (no stereo though but there are Eclipse speakers up front)
Momo Monte Carlo Steering Wheel (350mm) w/adaptor
Stable Energies Rear Cage w/ Provisions for Front Cage
M&R Four Point harness (both sides)
Sparco EVO III Drivers Seat, Stock Passenger Seat
IO Port Video Camera Mount
Interior From the rear of the front seats to the back of the car is gone.
The exterior is in ok condition. There is a scratch above the front drivers side wheel. Like if someone scraped their car door on it. There is also a dent on the driver's side door that is about an inch in diameter. The car does look okay it just needs a new coat of polish and wax.
Please let me know what the car is worth. Thanks in advance.
1986 944 Turbo
Engine:
SFR Hard Pipes
Fuel Rail Gauge
LR 3” exhausts
Suspension:
Steel Lug Nuts
MO30 Sway Bars
Interior:
Here is my unpleasant estimate....$6500 on the lowest of the ends.
To an enthusiast .....up to $10k
I could easily be wrong but that is my hat in the arena.
Hopefully others will throw their more knowledgeable (been there done that)hats in
And yes I know you have tons of great go fast parts and a stand alone engine mgmt.
