bent a valve- no broken belts - shop to rebuild head in pnw
Originally Posted by NZ951
If its performance, keep in mind the LR stage 3 head has been independently flow tested and proven to flow less than stated, similar to their intercooler... refer my Engine Analyzer thread.
I read that thread and Skunk specifically replied that it was only one head that was tested and it can't be concluded that they are are doing anything wrong based on one head. Your conclusion is way premature. You may wnat to hold the bashing until more testing is done.
Originally Posted by Skunk Works
I've only tested 1 (one) stage 3 head. No two heads are alike. It could have been a bad one. **** DOES happen once in a while. But then again...I have a St2 head tested too,and the trend is the same....
