Dyno results
Drive-by provocation guy
"starts dropping off @ 5K rpm)"
Not the turbo you think it is or WG not holding as much as you think. Either of which would explain those lower numbers.
I have a TO4E with 50 trim and a #8 hotside. I put down 325HP to the wheels with 19psi on a dynapack which tends to be slightly more stingy. How was your air/fuel ratio? Stock exhaust?
I'm suprised the dyno operator didn't include a wide band air/fuel report with the sheets. Probably a good idea to find out how rich you're running up top as you may be losing some power or worse washing the oil off the cylinder walls if you are really rich.
Originally Posted by jlturpin
I don't have a wide band. The narrow band shows rich (for what that is worth). The exhaust is no cat, but stock muffler.
John,
The narrow band I have is a LED unit, red, orange, green.... The car runs in the orange (above green) @WOT all the way to redline.
Jonathan
Jonathan
I would think that your #s should be significantly higher. Without a WB it is really hard to tell accurately where your A:F is at. I wish I could help more . . .
(Not to rub it in, but I got about 286HP/348tq to the wheels with stock k26/8 and AFM.)
http://home.earthlink.net/~jasoncoker/dynoresults/
Sincerely,
j
Sincerely,
j
Jason, what kind of wheels are those??
Awesome numbers. John, think you could get a chip done for my 43# (450cc) injectors???
Jason, was that run done with the WI ??
OK, got it. thanks.
Ski, any chance you could get with Jonathon to help out?
Or does everyone in AR not live close by Gotta be some major wide open roads out there though.
