Do you have a cat back? The biggest gain is going to be spool. Boost will probably increase less than 1 psi and horsepower increase probably about 5 rwhp.
Also depends on your cat and how it is. Mine was blocked bad so when I put in a 3" test pipe from Fabspeed I did see more power but at the same time 3 more PSI. After I turned the boost down to 15 PSI again I didn't see much more power but faster build up of boost though. The sound is awesome to!!
