removing thermostat completly
please help ,someone
i m new to this site and new to 944 turbo ,any way both of my cooling fans stop working so i m changing them in the mean time i want to pull my thermostat ,now is it alright to leave it out?
The thermostat circulates water around the engine during initial warm up through the center hole inside. When the thermostat opens, it closes this hole to prevent water from "short circuiting" and causing hot water to return to the engine without going through the radiator. Several have modified the water pump to run without the thermostat. Do not just remove it without the proper modifications.
If you car runs too warm, maybe it is time for a new pump, radiator or t-stat.
