Oil Pressure sender.
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
I've searched but with no luck and I know someone out there has to know the answer to this question. the posts on the oil pressure sender are marked with a "G" by one and "WK" by the other. There is a blue/white wire and a blue wire. Which wire goes to which post? If I hook them up backwards will it short out the sender?
TIA, Eric
TIA, Eric
I just looked on the wiring diagram in the factory manual for 86's. The solid blue wire goes to the WK terminal and the blue/white stripe wire goes to the G terminal. I don't think hooking it up backwards would break the sender either for what it's worth.
