Anyone have the SPEC clutch installed???
Just wondering if anyone has a SPEC clutch, stage I, II, etc. like Lindsey sells?
I am shopping and wanted some opinions on this.
Thanks to all in advanced!!
littlejt1, I have a new stage 1 in the box. If you decide to go this route, you can have cheaper than anywhere else..
I have the stage II, just installed recently (>1000 miles ago). I like it, but it takes a bit of getting used to. It's much harder to feather smoothley from a stop than the stock set up, but the pedal feel is great, not too heavy and not too light.
Got the Stage 3, with alu PP and alu FlyW. I got baaad shuttering! Used the clutch for almost a year now. But the feel of the clutch, and that its able to handle alot of torque is nice!
I have the stage 2. A little bit of chatter. When first installed pedal effort was same as stock, maybe even a little lighter.
Inexplicably, the pedal has become twice as hard after being parked for a weekend on ramps. No amount of bleeding has made it better. I don't know if this has anything to do with the Spec clutch but i'm inclined to think not.
Originally Posted by littlejt1
I see many of you stating you got some chatter...did it go away or is it still a problem???
Yeah it seems to get progressively worse the more stages you go up... Stage 1 may be a good option
I see someone has one for sale? Rennlist sponsor too!
I have Spec stage III with alu pp and fw. Works great, no shatter. I think mine works better than many others because I have new engine mounts. I think many of you out there with shatter should replace your engine mounts.
I never notice, anyway
stage 3 lightened clutch / alum flywheel. lots of chatter. better than the engine mounts, replacing the tranny mounts will help a lot. replace the rubber ones with kokeln solid metal ones.
I have a lightweight Stage 3 with about 1,200 miles on it now (bought before the alu option but not fitted). I hope it wil settle down as it's pretty bad for juddering (which I guess is English for what you guys call chatter?).
Is a solid trans mount OK or is it really harsh? Dave Lindsey advised me against the solid engine mounts even for my track car because I drive it on the street a bit.
