Fuel Mix problem at high boost
1986 944 Turbo, stock chip:
At boost of greater than 1.2, the fuel mix goes over-rich, and the car bucks. Here's what my mechanic has tried to fix it, with no change:
1. Change boost control (APC) valve
2. Checked all hoses for leaks
3. Unplugged the O2 sensor
4. Unplugged the TPS
5. Checked wastegate, ran full-open
6. Replaced ignition components
7. Replaced ECU
Next we're going to try replacing the airflow meter. Any other ideas?
Thanks!
7. Replaced ECU
Thanks!
