ummm kaaaay.. Why is my red (check engine?) light on?
The only time I have ever seen that thing on is if you leave the parking brake up.
Does anyone have a list of the conditions that cause that light to stay on.. or typical reasons for it staying on..
Everything else with the car seems fine
to the porsche gremlens
Any other lights on the dash? E.g. there is a low brake fluid light in conjunction w/ the '!'.
Any other symptoms? Poor running, down on power, low boost, etc.?
Does cycling the car off and back on clear the light or is it on permanently?
FYI, the switch that detects that the handbrake is down can move out of adjustment.
Originally Posted by aeronautica86
low oil level
I have good pressure, not that it meens much
However, I will check that out during my lunch break! thanks
I was thinking that but was not sure.
Are their any other typical things it will come on for?
I am banking on low oil..
Check for low oil pressure first, and that your brakes are working. If you are okay there, then it shouldn't be a major problem to content with and you should be fine to drive the car. Oil level, brake level and parking brake issues are the most common reasons for the light to come on, my money is on the parking brake switch. Jiggle it and see if that makes any difference.
Regards,
Regards,
But does your ABS still work Wes? My ABS light on my Passat comes on and off when ever it wants (have NO IDEA why, don't care b/c it is my daily) and when the light comes on the ABS doesn't work.
UAE Rennlist Ambassador
A few things
-low oil
-low oil pressure
-hand brake
-charging system (alternator)
-low brake fluid
-brake pads
-airbags (i think?)
-ABS
-low oil
-low oil pressure
-hand brake
-low brake fluid
-brake pads
-airbags (i think?)
-ABS
My newish front tires now have flat spots in them
ok it was just the parking brake pressure switch after some more investigation..
I will tighten and clean it all up later
Jerome, when are we going to have our germantown porsche meet?
Originally Posted by hosrom_951
A few things
-low oil
-low oil pressure
-hand brake
-low brake fluid
-brake pads
-airbags (i think?)
-ABS
-low oil
-low oil pressure
-hand brake
-low brake fluid
-brake pads
-airbags (i think?)
-ABS
A few things
-low oil
-low oil pressure
-hand brake
-low brake fluid
-brake pads
-airbags (i think?)
-ABS
-low oil
-low oil pressure
-hand brake
-low brake fluid
-brake pads
-airbags (i think?)
-ABS
