Need a few harness connectors
Does anybody have the connectors for the 3 sensors at the rear of the engine (harness side)? Mine have long since crumbled away and I'd like to splice a new connector and a few inches of wire back into the harness.
Honestly, I need as many of the connectors from the harness as possible, but these are by far the worst. If nobody has anything available, I'll have to wait on Quick Carl to get a NEW harness together and on the market.
Or, are there other options?
TIA
TIA
I have almost a complete harness that I have been using for the same purpose that I can give you some of the connectors. Let me know what you need for sure and I will see if I still have them.
PET shows them as "impulse sender" with a 944 part number and 2 required. The other connector I'm sure I need is the TDC sensor.
Aside from that, I need to pick through my entire harness and see what is broken or loose.
Lindsey have a complete injector harness for a really decent price.
For the connector, The only one I know of is the Cannon IT sure seal (02 sensor and turbo pump).
You may check on the 944/931/951/968 (water cool forum), there is a guy who is building a new harness, may be he can sell you some connector.
Good luck.
Good luck.
