Where to dyno in Nor-Cal?
Well, the graphs don't show boost so it's hard to say if your wastegate is giving up the ghost but at richer than 10:1 you would have to be losing at least 4psi on the top end and since its rich across the board I doubt this is the main problem. I suspect that adjustable fuel pressure regulator is toast.
In a previous dyno run at Devek the boost only got to its max of 13.46 at 4600rpm and then quickly started downward.......10.5 @ 5300rpm.....9.3@5900rpm......
The AFPR is brand new.........last mechanic purposely set the A/F rich so maybe he went too rich.....or as Tom has suggested I have a vacuum leak somewhere.
Andial,
I have a shimmed stock wastegate that you can have if you want to give that a try. If I remember correctly, I was running 16psi with it and the boost dropped down to about 14psi at redline. Not perfect, but pretty good for a stocker. Anyways...its free if you want it.
