Wrapping the exhaust headers?
Old 08-10-2005, 02:37 PM
theedge
theedge's Avatar
Why not ceramic coat it all?
Old 08-10-2005, 02:39 PM
reno808
reno808's Avatar
yeah do it. 1 its going to give you less engine bay temps and 2nd it will allow you to spoll up faster.
Old 08-10-2005, 06:37 PM
Epic2112
Epic2112's Avatar
Originally Posted by streckfu's951
Actually, its velocity not volume that the concern. As your exhaust gas moves through the pipes, it cools and slows down which creates back pressure. If you can keep your exhaust gas hotter for longer, it will maintain a higher velocity and reduce backpressure.
That's more or less what I said. As the exhaust gasses cool they contract. Since they take up less volume, they don't need to travel as fast.
Old 08-10-2005, 06:46 PM
streckfu's
streckfu's's Avatar
Gotcha.
Old 08-11-2005, 02:45 AM
ftanguay
ftanguay's Avatar
IF you want the best... put asbestos wrap! NOTHING is more efficient (but be carefull when installing, try not to inhalate too much...if possible)
PS: I always like the flame that will come after that ; )
Old 08-11-2005, 07:57 AM
special tool
special tool's Avatar
fatangay - link for asbestos wrap?
Old 08-12-2005, 02:21 AM
ftanguay
ftanguay's Avatar
I may have found a trail of a company who make fire blanket (100% asbestos). As soon as I get detail I can PM you.
Old 08-12-2005, 04:03 PM
toddk911
Drive-by provocation guy
toddk911's Avatar
I had ceraminc coating done. Prety good rates, and helps seal and small exhaust leaks.
www.hyperkote.com
This palce also onw can coat internal engine parts.
I went with ceramic as opposed to wrapping as I was shown before and after temp drop results on the headers. Was like 200+ degree drop.
This shop also has heat dispersing coatings as well. For IC or intake, etc.
Old 08-12-2005, 04:13 PM
Mike Murcia
Mike Murcia's Avatar
I'm surprised nobody has chimed in about the inner wall of the exhaust pipes collapsing due to the greater heat.
Old 08-12-2005, 05:12 PM
streckfu's
streckfu's's Avatar
I never heard of this happening to the exhaust manifold; only the turbine to exhaust pipe.
Old 08-12-2005, 05:20 PM
Mike Murcia
Right, but the hotter the temps are to the turbo, the hotter the temps will be after the turbo. Don't get me wrong. I've got my headers wrapped all the way up to the turbine, so I'm obviously not too concerned. It's just an argument some have made in the past.
Old 08-12-2005, 05:27 PM
streckfu's
streckfu's's Avatar
I never thought of that as I have a test pipe and removed the affected pipe (it was collapsed) but for those with stock systems, it is well worth bringing up.
Old 08-12-2005, 06:51 PM
Dilberto
Dilberto's Avatar
Default Anyone Make an Expandable Crossover Pipe?
I see alot of those "Imports" have nice GReddy stainless, with cross-hatched expansion joints. Who can weld like other?
Old 08-12-2005, 07:40 PM
Mike Murcia
I never thought of that as I have a test pipe and removed the affected pipe (it was collapsed).
Yeah, I need to get a test pipe.
Old 08-12-2005, 09:43 PM
Crazy Eddie
Crazy Eddie's Avatar
I personally would, and did, go with Jet Hot Sterling, both in and out
I did this because there are a number of guys on this board that I respect and that are very knowledge
that used Jet Hot also
It is a ceramic coating not as heavy as Swain ( I didn't want to remove my heat shields & the swain looks like a mummy )
I will dig up a jpeg of it and post
It also is very reasonable ... I paid like 100 bucks Which is pretty cheap
As for who to ask for at Jet Hot, Matt is the guy who helped me he is a
great guy.
Regards
Ed
Quick Reply: Wrapping the exhaust headers?
