Direction of oil flow to/from the cooler???
As per the Subject line... Can someone (who knows) pls. tell me which is the outlet and which is the inlet of the connections to the engine (cooler housing) to/from the remote oil cooler??
TIA
TIA
Don, the bottom hose on the oil cooler is the inlet, the top is the return. ICR where they mate up to the oil cooler housing, if they cross or what. Our top line goes the second cooler, then out the bottom of it, back to the engine - but that cooler is inverted. As you can see the external cooler was left out of this diagram. HTH
Looking to add a second cooler like your setup and am starting to gather the needed bits, like the correct angle AN fittings...
