topspeed?
#31
Originally Posted by toddk911
Anyone done "highspeed" or "on the car" alignments/balance ?
Does an "on the car" wheel balance exist? I've heard it mentioned, but never seen it offered anywhere. Until I find a competent shop to balance my wheels, I'm not shooting for a top speed.
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
#32
278km = 173 ????
My 303km/h (189mph) run was done with a T04E and 7000rpm redline with 18" wheels. That was fairly scary. The car's not very stable at that speed.
#33
Even if your speedo isn't accurate, that is no defense in court. The fact that you thought you weren't speeding doesn't change the fact that you were, especially if you got caught on radar. And if your speedo was dead accurate, experience has shown me that your creditabilty on testimony you weren't speeding is zero.
#34
Speeding tickets is all about the money here.
#35
#36
Sam
#37
UAE Rennlist Ambassador
Does an "on the car" wheel balance exist? I've heard it mentioned, but never seen it offered anywhere. Until I find a competent shop to balance my wheels, I'm not shooting for a top speed. ![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
Got 268kpr at 6,200rpms, still had room, but i don't push it and that was a 'i wonder how fast it goes' thing.
#38
Rage: In NY if caught you'd be in jail for that speed, and not have a license. And if there was any road traffic I suspect you'd also be facing crininal charges rather than just traffic violation. In NY your inaccurate knowledge of your actual speed is not a defense, but if the judge is looking for a reason to "move" cases it is as good a resaon as any. My frame of reference is from being a former ***'t DA and now criminal defense atty. As an ADA I would reduce any routine speed ticket if you asked. Surprizingly not many even asked. I couldn't imagine any Judge I have been in front of here in NY would consent to a reduction of a 145 mph ticket. That would have been a "keeper".
On balancing wheels, from experience the Cup Porsche wheels will nor retain clip weights. The adhesive tape style weights inside the wheel must be used. Yes there are some shops that have on-the-car balancing units. I have never found it necessary up to the 135ish I've gone, as the wheel-spinning type worked fine. Are you sure that your wheel and/or tire is not out round? Brake disks checked for trueness? I'd suspect a tire problem. One with the tire cords may be failing so as not to be round anymore at speed.
#40
Originally Posted by shaheed
actually i have been sitting in the courtroom when someone was "let off" because of an improperly calibrated speedometer that told him he was going slower than he actually was. it was not applicable in my case because the speedometer said i was going faster than i actually was.
#42
Originally Posted by SoloRacer
I had the exact same problem. Did you consider getting some used tires with a really tall sidewall and getting it re-tested? Not saying that is what I did
but it can get you a few mph difference if that is what you need.
#43
OMG, Rage!,
I didn't think anybody, here, would've got caught going faster than me, which was 194 km/h (and he didn't drop it down). On the side of the road, the officer made some sort of comment about me being his biggest fish ever. I felt like telling him that he only caught me because I slowed down, pulled over, and waited for him. And that's the way it was! It was in the middle of the night, lit up major highway, and nobody else on the road. The next exit was just coming up; I should have taken it and disappeared. It took him forever to come out of his hiding hole (I saw him way too late) and come after me. I think he was contemplating if he should even bother; but then I slowed down.
Same as you, Rage. Settled for 700 bucks!
#44
FWIW,
I recently checked my euro-speedos (both the S2 and the Turbo) against the km-markings on the motorway. Both timing and marker positions are pretty accurate as I can get reproducible measurements for several consecutive runs to within 1 or 2 tenths of a second (over 20 - 30s).
Both cars have nearly identical numbers, although the S2 tires are 1/2 worn while the Turbo tires are new.
For a real speed of 60 km/h, I need to go 67 km/h indicated
80 real = 88 indicated
100 real = 108 indicated
120 real = 129 indicated
140 real = 151 indicated
160 real = 173 indicated
180 real = 195 indicated
Then I had to stop - too much traffic
I've had the S2 up to 260 indicated once, so this should be very close to the factory figure of 240 km/h.
Tommy
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
Tommy
#45
Heck, just tell them you made 170 by your speedo and that your speedo reads up to 180. Who cares about the error percentage considering most speedos don't read over 85 or 100 anyway. Most should be impressed that your speedo goes that high whether the car can do it or not.
