Cycling valve replacement
Probably not. I thik it would take the fingers of a 5 year old to get at it. Good time to upgrade that LBE to an EBC.
I think you'll have to remove the intake manifold. Good time to remove the venturi and clean things up under there.
I plan to run the car in PCA F-Stock so the cycling valve has to remain. I just had the intake manifold off for a rod bearing job. I hate taking it apart again.
Anthony
Anthony
I was just going to mention turbox's post. We fixed my broken nipple (to wastegate) with the intake manny on. You *Might* be able to replace it with the manny on, however, it will be tough.
That Guy
Wow what good timing. 50$ shipped.. i kind of feal stupid cause i paid 66 for it but you guys cant even get it for under 90!. So my loss your gain let me know if you want it ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
-Ian
-Ian
It can be done w/o taking the intake off, but its a pain. Ive done it about 5 times or more on three different cars - so it is possible.
And since you are removing a bad one, its less trouble, because the biggest difficulty is getting the hoses off the valve w/o busting the nipples off. However, if you do bust a nipple off in one of the hoses, its difficult to clean the chunks out of the hose with the manifold on. So be careful.
Might as well give it a shot. If you cant get it off or the new one on, pull the manifold then.
Saw my mechanic do it on my car. If I hadn't seen it with my own two eyes I wouldn't believe it. Need some looooong tip needle nose though. Took about 10 minutes maybe. He changed it out trying to chase down a boosting problem
Taking the intake manifold off can be done in under an hour. Its not that hard really! I just did to paint and it was a good thing I did because I found 2 broken vacuum lines(which I ended up replacing almost all of them) and found my cycling valve to be broken. I had a MBC so I was not aware it was broken. But I say its a good excuse to clean things up!
Good luck!
Good luck!
