Will MAF work?
Hey guys!!
i just met this guy here in PR that owns a 951 and we got talking and he is interested in my Huntley Racin MAF and ARC2 controler. now the question is will it work with his set up. he has a HP kit from Europroducts. will those chips work with MAF or will he have to get chips tuned for MAF.
TIA
TIA
The MAF + ARC2 were designed to work with AFM chips. This is not the best approach, as it has many issues, but will work. Do you have AFM or MAF chips on your car? Probably AFM chips, otherwise there is no need for the ARC2.
Thanks everybody. yes he does have AFM chips. I'm running MAP. soon to swap to Vitesse stage 3, hopefully.
anybody interested in Guru's stage 2 map with 65# inj. and K27/8. tuning module included and serial link also.
Well exact numbers i don't know but I know at least 6 friends with 951's and one looking for a white low mileage (>50k) car, he is into concours. i've seen more on the street.
by the way I told Juancho to buy your kit.
Thanks the MK-IV is my father's he bought it and i bought his 951. it was his 50th birthday present. soon to have 700 on pump gas. right know it has 710 on race gas.
i had almost the same setup u were explaing. I had europroducts chips huntley stage # MAF and arc-2. i had no problems with it except when trying to run higher boost and when i upgraded the injectors. once the injectors were upgraded it ran like **** and got guru chips
