Temperature related idle problem
Any idea why idle should increase during warm weather ( >30 degrees C ). I suspect the air temp sensor in the airflow meter - can this be replaced separately ?
UAE Rennlist Ambassador
Not sure on the replacement of the AFM temperature sensor, but there is a DME Temp. Sensor on the block that could be faulty.
Wouldn't hurt to check it: Click Here
