Engine Blocks - NA and Turbo
I tried search and came up dry so I'll ask it again...
What are the differences between the 944 NA and 951 engine blocks ?
Hey Man
Supposedly the oil passages in the "early" N/A blocks were smaller than the turbo also. This hasn't prevented them being used in a turbo application though. Besides the oil tap for the turbo weren't the bearing shells for the balance shafts mounted differently also. They do look different in PET, I'm pretty sure the shaft covers won't interchange with the later blocks.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Shaft covers are not interchangeable between any engines – they are align bored to each specific engine (and then stamped with that engines ID number)
The Series I and Series II engines have different sizes oil main galleys. (Series II are bigger and, in theory, better).
After a certain point in the series II production (a good guess is late 86) the NA blocks had all the needed parts to supply oil to the turbo – they just have to have the upper balance shaft cover tapped for the fitting.
The most important difference – the NA blocks are generally in much better shape!!
Chris White
Chris White
Campeck Rulez
oh....hmm. nvm then.
edit. are you completely positive. arent the knock sensors on the driver side up near the head. next to the water temp sensor?
i have an 86 block in the garage and i dont see any.
