Official oil drain plug temp sender group buy!
#106
Lifetime Member
Lifetime Member
What are the 2 most important add-on gauge to have: boost & oil temp?
I'm thinking of scrapping my AFR gauge since it's only accurate at idle. True?
#107
Deitz, I am using sender 323-057. Use a 1/8x27 NPT tap, two wraps of teflon tape and be sure to check for electrical continuity between the plug and sender through the tape and of course check for leaks.
Cheers
Cheers
Originally Posted by JDeitz951
Brad,
What sender are you using? I am going to drill & tap my plug in my own machine shop. I picked out 323-057 at egauges.com, will this work? Going with Cockpit Black series boost 150-063 and temp 310-012.
#108
Lifetime Member
Lifetime Member
Cheers
Cheers
Are you buying them from egauge.com? If so, I guess I'll be backordered until you get yours!
On the FAQ at egauges.com, they recommend you don't use teflon tape or anything. When I finally get to that point, I'll try without and see how it goes.
Rock on!
#110
Thanks for the info!
Rock on!
Rock on!
As for the teflon tape, I know they say not to use it, but my experience is that it will leak if you don't, and you can also strip the delicate brass threads very easily. Using tape is fine so long as you only use a couple of wraps and check continuity to make sure the tape has broken through enough. I've made 32 of these things so far and have yet to have 1 that didn't pass the continuity test first time with teflon tape.
