CLUTCH JUDDER IN FIRST GEAR
HI ALL,
I'VE RECENTLY HAD A NEW SPEC STAGE 2 CLUTCH FITTED TO MY CAR. THERE IS A JUDDER IN FIRST GEAR WHEN TAKING OFF BUT IS FINE OTHERWISE WHEN GOING UP THE GEARS, THERE IS ALSO A SLIGHT JUDDER IN ALL GEARS WHEN CHANGING DOWN........ANYBODY GOT IDEAS ON WHAT THE PROBLEM COULD BE AND HOW TO REMEDY IT? THANKS...
EVERYTHING WAS FINE WITH THE OLD STANDARD CLUTCH PRIOR TO FITTING THE NEW SPEC ONE . I ONLY CHANGED IT FOR THE SPEC SO IT WOULD HANDLE THE EXTRA TORQUE AND HP.... I DONT KNOW IF ITS A DUD CLUTCH OR WILL IT BED IN AFTER A WHILE?????????
That Guy
Hey man,
The clutch is just fine don't worry. The problem with the judder is because it is a pucked clutch. The first gear judder i don't think you can fix but when down shifting if you give the car a little gas, almost like double clutching it will not judder. I know this because when riding in ted wrights car with his 6 puck state 2 clutch it will judder a little in first, not terribly, but if you down shift with out giving it a little gas it will shake the whole car. I do not think it is any thing to get stressed over though.
Cheers
-Ian
Cheers
-Ian
Did you have the flywheel surfaced? Also, they recommend with the spec stage 2 to do 500 easy, stop and go miles before applying full throttle to bed in the clutch.
Another wierd thing that can happen during clutch changes is the one of both of the exhaust hangers could be loose. The S2 I had, had a serious shudder when downshifting into 2nd without rev matching. Turned out that the (2) hangers were detached and it was the exhuast causing the shudder/vibration. After reattaching the hangers, it was as good as new.
Just one more thing to check.
Originally Posted by TurboX
Hey man,
Cheers
-Ian
Cheers
-Ian
Originally Posted by special tool
The most important question is....
Where is the dyno sheet, man? With a name like that, you gotta show the sheet.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
THANKS GUYS FOR THE INFO ON THE SPEC CLUTCH JUDDER ISSUE....IT SEEMS I'M NOT THE ONLY ONE WITH THE PROBLEM AND RECKON WITH MORE MILES IT WILL BED IN PROPER ( HOPEFULLY !!!
SOME OF YOU WERE ASKING FOR THE DYNO SHEET FIGURES BUT THEY ARE NOT WITH ME AT THIS LOCATION.......HOWEVER.........
ANYBODY WISHING TO CHECK MY CAR OUT CAN SEE IT AND THE FULL LIST OF MODS AT WWW.PROMAXMOTORSPORT.COM
SCROLL DOWN THE LEFT HAND SIDE MENU TILL YOU COME TO " CARS FOR SALE" CLICK ON THE 89 G 2.8 ROAD CAR AND YOU'LL GET TO SEE MY CAR. I BOUGHT IT IN AUGUST OF 2004 AND IT NOW RESIDES IN IRELAND WHERE I'M FROM BUT I'M HERE IN FLORIDA AS MY WIFE IS AMERICAN. I'VE PUT CUP 2 WHEELS ON IT SINCE I GOT IT AND FITTED THE SPEC CLUTCH RECENTLY...I'LL HAVE TO WAIT TILL XMAS BEFORE I'M HOME TO FIRE HER UP AGAIN!!
THANKS AGAIN FOR ALL THE ADVICE! BTW....ANYBODY GOT A GOOD POWER STEERING RACK FOR SALE? MINE IS LEAKING..... CHEERS.
I never notice, anyway
btw, turn off your caps lock! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
this thread is interesting - i get my car back tomorrow with my new spec stage 3 hybrid lightweight clutch, new PP and new alum flywheel.
just got it back. WOW is there chatter when i start going in first gear. i find the best thing to do is slip the clutch as little as possible. get a little grab then give it some good gas to get through it quickly.
but DAMN that lightweight clutch and lightweight flywheel ROCK!
DUDE! THAT DIDN"T TAKE FOUR WEEKS AT ALL! I"LL CALL YOU LATER> GOTTA KNOW ABOUT THE REBUILD ON THE NGINE! like my caps
Call me later on, or pm me today. Gotta know, and maybe get a ride. E
