Anyone else experience this phenomanon?
Whenever I use my power windows, my water temp gauge moves up while I hold the window button. Then when I release, it goes back to where it was before.
Check your grounds, your lights are putting a drain on the power, which is affecting the voltage going to the coolant sensor, consequently affecting your gauge reading.
Iceshark knows way more about this than me.
-Jon
-Jon
Replacing the negative battery cable (which looked good at first, eventually was all cracked up) with Ice Shark's replacement and problem solved (as well as a few others).
