Dyno results - APE II @ 14-15 psi
#31
1 Post
Originally Posted by streckfu's951
Its a number from Porsche. It should be mentioned in the specifications or even the owner's manual.
The driveline loss is the difference between the crank hp (bhp) and the hp as measured at the wheels (as ambiguous that is). The clutch, torque tube, gears, and axles all consume power. How much is a combination of a large number factors. Weight, friction, etc all play a part.
Someone should be able to look this up in either the factory manual, haynes, or something.
I'm out of town and can't look it up.
#32
It's not an issue of bench racing. I'm not trying to inflate numbers as what's at the wheels is all that matters. I was just pointing out that the "crank" numbers on the dyno were guesses (and bad ones at that).
#33
