Change Rod Nuts For Rebuild? Where To buy Piston Rings??
Rocket Scientist
Should I change my connecting rod nuts during my rebuild?
Also, paragon is out of piston rings. I am curious on where to buy them...I was told that reg 944 piston rings are not the same as 951 rings. Every other vendor I look into besides Paragon sells the 944 and 951 rings like they are the same. I am in a hurry to finish my engine, like everyone else
, and would like to know where to pick some up? Thanks
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
951 rings are different than 944 rings. There is some speculation as to whether 944 rings can be safely used in a 951 application. I cannot say for certain, so I searched out and found 951 rings to be safe.
I got my set from EBS, and they are the correct 951 parts.
And it is pretty common advice to use new rod nuts. I think the factory manual also recommends to do so.
Jane Bond 007
Yes, change the rod nuts. They're only a few bucks and it's not worth cutting that corner as it cost tons to replace them later.
