too much fuel
too much fuel
anyone have any ideas as to why i might be getting too much fuel at idle its sputters and it smells of fuel and at a round 3000 rpms it sems to clear up and run smooth.
thanks
Doug
thanks
Doug
i was thinking the same thing....my first turbo blew out a seal and threw oil through out the entire exhaust system and into the intake(what a mess) and the 02 sensor looked alittle blackend ill try it tomorrow....thanks chris
My failing FPR started doing a similar thing, rich at cold idle, stumbled, ran OK above 3K but blew black fuel smoke under hard boost. Replaced FPR and no problem. Between the bad FPR and couple of vac leaks my plugs were absolutely coated in unburnt fuel, #4 was the worst by far.
Check (not in any order)
- Vacuum leaks
- O2 sensor
- Fuel Pressure Regulator
- Eng Temp Sensor
- Intake Air Temp Sensor
- Clean AFM connector (AFM sensor to wiring harness)
- Voltage at idle from AFM (should be 0.6-0.8v)
- If all checks out, I would start looking at the injectors.
- Vacuum leaks
- O2 sensor
- Eng Temp Sensor
Are you runing non-stock injectors? Or you have 2 sets of stock injectors?
If you are running larger injectors or higher fuel pressure then it will run rich unless the software compensates for it.
