Guys, just installed a boost gauge, what vacuum readings are you seeing at idle once the car is warm?
How bout boost readings from a 951S with the weltmeister chip set?
I'm seeing 14 inches of hg at warm idle. Haven't gotten boost readings as I tightened up the fittings after a drive and then my bro in law parked me in...
Ok, sounds like I'm where I should be. I'm up 5000 ft above sea level, usually will have 3-4 inches less vacuum up here vs sea level, so that's around 17-18 at warm idle...
