My last dyno number is here. I'm running lean?
RPMs HP SAE TQ PSI
2708 37.982 72.721 14.68 0.58 1.00
2822 65.653 120.631 12.63 2.36 0.86
2881 66.731 120.118 12.60 2.53 0.86
2990 68.943 119.560 12.58 2.90 0.86
3108 72.684 121.273 12.69 3.59 0.86
3198 77.242 125.264 12.88 4.46 0.88
3291 84.081 132.504 13.21 5.48 0.90
3386 92.659 141.890 13.52 6.58 0.92
3485 102.557 152.579 13.67 7.89 0.93
3592 113.721 164.177 13.61 9.48 0.93
3693 125.600 176.346 13.44 11.30 0.91
3805 139.536 190.170 13.23 13.17 0.90
3912 155.528 206.172 13.04 14.45 0.89
4008 174.554 225.844 12.92 14.94 0.88
4102 191.461 242.038 12.79 14.85 0.87
4202 205.203 253.206 12.58 14.69 0.86
4291 213.181 257.641 12.42 14.54 0.85
4410 218.281 256.649 12.35 14.46 0.84
4482 220.065 254.613 12.21 14.47 0.83
4592 223.121 251.934 11.88 14.46 0.81
4712 225.014 247.610 11.52 14.34 0.78
4811 226.892 244.562 11.17 14.13 0.76
4887 229.198 243.160 11.15 13.93 0.76
4989 232.002 241.109 11.29 13.68 0.77
5105 234.663 238.376 11.50 13.58 0.78
5201 236.318 235.599 11.63 13.49 0.79
5300 237.988 232.857 11.67 13.37 0.79
5398 239.935 230.478 11.81 13.19 0.80
5497 239.680 226.078 11.85 12.92 0.81
5594 241.387 223.749 11.94 12.77 0.81
5720 243.300 220.566 12.10 12.53 0.82
5813 241.338 215.268 12.11 12.25 0.82
5908 240.376 210.989 12.15 12.13 0.83
5999 238.543 206.179 12.27 12.03 0.83
6098 236.179 200.834 12.23 11.89 0.83
6196 233.042 195.027 12.19 11.70 0.83
6227 231.763 192.974 12.23 11.63
0.83
0.83
I never notice, anyway
i think you labeled your columns wrong. i take it that your A/F ratio is the 4th column and PSI is the 5th?? if so, youre starting a bit lean but then getting rich at ~5000 rpm, which is ok. although it seems then like 2908 rpm is an anomaly - the A/F ratio would have to change drastically between that and 114 rpm later.
Monkeys Removed by Request
as stated earlier I think you labeled your columns wrong but, you arent lean. Low 12's at peak is just fine. Its when you get mid 13's and higher that you need to worry. You could lean out the midrange some your mid to low 11's throughout most of your peak tq area. You could be mid 12's there no problem and pick up some hp and gas mileage.
Drive-by provocation guy
Yea, you could turn up the boost to 18 psi and still be safe. Your chips are mapped to run 18psi so run it ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Especially since you are not holding full boost to redline, which is like a natural saftey device![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Since you have the Tial I would guess the boost roll off is due to stock turbo. With those chips you should be seeing at least another 20-30hp/tq.
Originally Posted by special tool
13.67 before torque peak is dangerous. You do NOT want 13.67 here - you are margnally safe. Do not raise boost any more.
werd.. this chunk right here could use a bit more fuel.. aside from that its pretty good..
"13.67 before torque peak is dangerous."
Thats not there to help spool up?
And 152tq is still a good bit from peak tq.
I run 95 octance fuel all the time i hope it would be ok. My next mod is K27/6 and ask Danno to remap and tune it. Will i get 280whp on K27/6 with stock airbox?
Thank you all,
Jim
Thank you all,
Jim
